Drain To Vent Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-30-2012, 08:20 PM   #1
Drain to vent pipe
Hi!!
Simple question. Hope someone can answer real quick.
I am remolding my bathroom and trying to keep it simple.
He is the story, my house is a pre-fab and the person who did the bathroom that I am redoing decided to connect the "T" connector to the vent pipe, which is not the issues, the ass hat off set the "T" to a degree of 80* vs. the normal 90*.
My question is, if I cut out the "T" connector, how do I replace it since I am cutting out the vertical pipe thus removing more pipe then I want to?
Chris
Ccusum is offline   Reply With Quote
Old 10-30-2012, 09:04 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 904
use 1 or 2 couplings and pipe to fill in the gaps. Hopefully one end of the pipe has enough play to allow for the couplings. If not, get some shielded couplings, you can fold them back on top of itself so you can slip the pipe in
Old 10-30-2012, 09:05 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
How far do you need to offset the line? If it's offset slightly like that, sometimes a 1/16th bend can make up the difference.
If you must cut it out, you need a regular solvent weld coupling for the lower portion, and a fernco shielded no-hub coupling. The no hub coupling will fold over itself, giving you enough room to glue the lower coupling, and once the fitting is in place, you can unfold the fernco no hub back over the upper portion of the pipe and tighten the sheild over it. Very easy.
Journeyman Plumber
AC drain pipe vent trap going dry - sewage smell denemante Plumbing 6 04-26-2011 06:52 PM
3" drain vent pipe going thru shed roof amakarevic Building & Construction 1 02-08-2011 02:50 PM
Washing Machine Drain Pipe tjeieio Plumbing 2 02-25-2010 05:19 PM
Drain Pipe MrMrsSip Plumbing 2 11-21-2008 05:46 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
