Drain And Vent Layout Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-03-2013, 08:15 PM   #16
Rewards Points: 1,858
Originally Posted by TheEplumber View Post
lol- he answered that in #4 as well as stating UPC
Must be the senile old plumbing inspector day....
Old 10-07-2013, 12:14 PM   #17
I guess I could go with a rear flush toilet if I don't have the proper depth of 15"?
jkg81 is offline   Reply With Quote
Old 10-07-2013, 07:31 PM   #18
Master Plumber
Benplumbing's Avatar
My question would be for E.. In that code do they allow you to circuit vent fixtures. ? If so he could run a three inch line in the middle of the room heading up towards the toilet and shower with a single event in between the toilet and Y fitting for the shower. Head down towards bathtub and vent that with one of the sinks.
Benplumbing is offline   Reply With Quote
Old 10-07-2013, 08:36 PM   #19
Plumber
TheEplumber's Avatar
Rewards Points: 554
circuit vent is not listed in UPC definitions.
What you are describing above- I would call horizontal wet venting, for lack of a better term, which is not allowed per UPC.
Idaho has recently adopted it's own hybrid version of the UPC we call IPC(Idaho Plumbing Code) Although I haven't reviewed it thoroughly, it does allow for some circuit vent applications for residential work
Tags
drain , layout , plumbing , sewer , vent
Can I split a main drain vent stack? -- SpinFly Plumbing 14 08-15-2012 10:32 AM
Moving Tub Drain - Vent questions CharlieR Plumbing 4 03-11-2012 05:36 PM
AC drain pipe vent trap going dry - sewage smell denemante Plumbing 6 04-26-2011 06:52 PM
drain to drain to vent? ryanh Plumbing 0 07-12-2010 12:07 PM
AAV or Studor Vent Needed for this Tub and Shower Drain? BillyDIY Plumbing 1 12-16-2008 11:11 PM
