Drain And Vent Insulation - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-21-2006, 02:09 PM   #1
Rewards Points: 150
drain and vent insulation
After removing the kitchen sink and the wall, I notice the builders packed some plaster around the drain and vent pipes where they pass through the framing.
I assume that this is method of fire blocking. So, as I have knocked away a lot of it, would some type of spray foam be advised to fill in the spaces? Thanks
handifoot is offline   Reply With Quote
Old 05-21-2006, 06:27 PM   #2
joed's Avatar
Rewards Points: 12,012
They make fire rated caulking just for this purpose. Unless the spray foam is fire rated then it would not meet code.
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 12:54 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 07:34 PM
drain slope ouchmythumb Plumbing 2 05-12-2007 06:12 PM
Dishwasher Drain Question kypper Plumbing 2 01-16-2007 12:39 AM
Ok to use a sanitary cross in a wet vent? peeks Plumbing 1 10-03-2005 05:35 PM
