-   -   drain and vent insulation (http://www.diychatroom.com/f7/drain-vent-insulation-2545/)
handifoot 05-21-2006 02:09 PM
After removing the kitchen sink and the wall, I notice the builders packed some plaster around the drain and vent pipes where they pass through the framing.
I assume that this is method of fire blocking. So, as I have knocked away a lot of it, would some type of spray foam be advised to fill in the spaces? Thanks
joed 05-21-2006 06:27 PM
They make fire rated caulking just for this purpose. Unless the spray foam is fire rated then it would not meet code.
