Drain/Vent - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-14-2009, 06:15 PM   #1
Drain/Vent
I'm installing a double sink vanity in our bathroom remodeling project. The vent is to the right of both sinks so I need to run the waste drain from from the first sink past the second sink to get to the main line. I'm using a 90 at the first sink, a sanitary tee at the second sink and a long sanitary tee where the drain meets the vent.
Any concerns with this layout?
When you install the P-Trap there is a pipe that goes from the trap into the wall. The wall has a threaded fitting that allows a ring to seal the pipe. What is the threaded fitting called----P-Trap Adapter?????
MikeyP is offline   Reply With Quote
Old 03-14-2009, 06:19 PM   #2
It may be a long sweep where the drain meets the vent not a long sanitary tee. I don't know the difference
Old 03-14-2009, 06:45 PM   #3
GC/Master Plumber/Mech
Rewards Points: 560
male adapter
Old 03-14-2009, 09:04 PM   #4
Do you know if my layout of fittings is correct?
Old 03-14-2009, 09:34 PM   #5
Rewards Points: 560
Can you post a pic?
Old 03-15-2009, 11:05 AM   #6
Does this look ok? Double sink vanity venting to the right of both sinks
Drain/Vent-bathroom-001.jpg   Drain/Vent-bathroom-003.jpg   Drain/Vent-bathroom-002.jpg   Drain/Vent-bathroom-004.jpg
Old 03-15-2009, 12:16 PM   #7
Rewards Points: 560
That looks fine. I would have used a directional "T" but for this you shouldn't have a problem with a sanitary "T".
What you need now to tie in your sink drains is a 1 1/2" male adapter for the the size of pipe you uses. I can't tell by the pics but it looks like 2"
Don't for get to couple the splice between the "T" and "90"deg
before you install the sinks make sure you install the drain/pop-up assy. It is easier to do while out rather than trying to do it while the sink is installed.
After you have the sink installed all you need to do is to install a P-trap off the sink drain to the male adapter.
What are you doing for Hot/Cold water supply?
Old 03-15-2009, 08:16 PM   #8
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
It should work fine as long as you arent having it inspected. If you are, then you may have a problem with that tee on its side. At least you would here. Here it would have to be a tee-wye aka a combo fitting (wye and street 45) like you have on the vertical section. These can be a PIA when you're fighting for room. You cant have a tee on its side or on its back for drainage. In addition, your trap to vent distance may be a bit long...not sure. Its rather hard to tell from a picture. If the trap is too far from the vent you could cut in a tee or tee wye on its back between the two drains then back vent it into the stack. But, like I said what you have there should work fine as long as you arent having it inspected.
The fitting at the wall is called a trap adapter or around here we call them "desankos". Not sure why the desanko name...probably a brand from way back.
JDC is offline   Reply With Quote
Drain/vent in exterior wall options wildbilly Plumbing 12 03-14-2009 04:21 PM
Shower Drain/Vent handyman923 Plumbing 1 10-19-2005 08:14 PM
