06-03-2008, 10:26 PM
#1
drain trap
I need to repair the main drain line below the basement. It is an 8" clay "P-trap" Do I have to replace the P-trap with another p-trap or can I just use a length of straight pipe?
06-03-2008, 10:52 PM
#2
Journeyman Plumber
drain trap
If all fixtures in the house have a p-trap attached to them, then a house trap is not needed.
Fix it right the first time, so you won't have to fix it a 2nd time.
06-03-2008, 11:45 PM
#3
Doing it myself
drain trap
Also note : "I don't care who ya are, thats goin' to be disgustin' right thurr."
Journeyman Plumber
06-04-2008, 10:02 PM
#4
drain trap
Thanks for the reply. I think the plumbing was done by the local 5th grade class. So maybe a main trap would be the way to go. Forgot, this house was once an orphanage. They had a dozen toilets in the basement once. the drains are still there in the ground, no traps on any of them. I tried to find a trap for 8 inches, no luck. Any suggestions?
06-05-2008, 12:54 AM
#5
Doing it myself
drain trap
You won't find any traps on those toilet lines, since traps for toilets are integrated into the bowl themselves.
If they are not currently being used for toilets, they should be capped in some manner if you are going to remove the 8" trap....
Journeyman Plumber
06-05-2008, 09:19 AM
#6
drain trap
I have never quite understood the reasoning for "house traps" since they are usually on the sewer main side of the house plumbing. This would indicate that they are not vented and could have the water sucked out with any flow in the main sewer line. Toilets do not have a trap under them since it is built into the bowl. Double trapping is illegal in most Plumbing Codes.
If you have never made a mistake, you haven't done much.
06-05-2008, 10:23 AM
#7
Doing it myself
drain trap
Didn't they used to put a large end of line vent on those types of systems 'back in the day' ?
Journeyman Plumber
06-05-2008, 11:11 AM
#8
drain trap
That may be true. The few that I have seen were outside the foundation and no vent past them to make it work properly. Every Code I have worked under requires a trap for each fixture (including a washer drain) so in my mind, a House trap would constitute double trapping. In Ohio. to get a Plumbing Regulation changed (drainage type) they built a system in glass pipe. It was then tested 100 times and if there were no failures, the code was changed to allow it. When I first strated my apprenticeship, you could only run 20% of vent lines horizontal. After testing this, it was changed so the only requirement was proper slope and it had to exit through the roof.
06-06-2008, 10:19 AM
#9
Doing it myself
drain trap
Our code says that building traps are not permitted anyhow.
Journeyman Plumber
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
