Drain Tile Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-24-2011, 12:16 PM   #1
We live in Vancouver in a 90 year old home. We have decided to renovate our basement. The contractor discovered serious mould in the basement and as a result it has been necessary to replace the drain tiles. The excavations have been completed and our home looks a like a WW1 battlefield. The issue is the type of sealant to be affixed to the foundation walls. The drainage contractor has already rolled on two coats of the black goop. This is necessary but is it sufficient? I do not want to undergo this process again. We have no intentions of moving. This is our dream home. The issue is whether to affix the plastic "Dimple Board" to the foundation walls. Does this help? Is it necessary? The contractor wants to charge an additional $3,000.00. Is this reasonable? This exercise has become very expensive and we want to contain our costs.
Almost Insolvently Yours
Sophie
Sophie12 is offline   Reply With Quote
Old 04-24-2011, 01:03 PM   #2
Rewards Points: 1,542
I do not think you need the dimple board. What counts is that you do not have water pooling up against the foundation and that your drain tiles down below are working properly to carry any ground water to a sump pump.
Tile Roof Replacement alkali Roofing/Siding 3 01-04-2011 08:17 AM
Still leak after weeping tile replacement mondaysick Plumbing 3 11-04-2010 08:45 PM
Drain Tile Recommendation: guha5006 Plumbing 2 08-05-2010 04:35 PM
Foundation cracks drain tile fiveoh018 Plumbing 3 06-26-2010 02:55 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 09:07 PM
