Drain Tile Around Footing - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-17-2012, 04:57 PM   #1
drain tile around footing
So I have a house that has water issues in the basement. The top of the grade down to the footing is close to 6 ft.
I'm wondering if the ez drain tile can handle that weight.
Thanks, Jim
pasquinnal is offline   Reply With Quote
Old 07-17-2012, 05:05 PM   #2
Rewards Points: 13,300
Never heard of it.
There's lots of things you can do to help keep that basement dry.
Working gutters with drain far from the foundation.
Regrading so it runs away from the house.
No mulch pilled up againt the foundation.
No flower beds forming ponds for water to lay.
French drain.
Old 07-17-2012, 09:25 PM   #3
firehawkmph's Avatar
Rewards Points: 1,822
Pasq,
in my neck of the woods in northeast Ohio, most cities require schedule 35 4" pvc pipe for footer drains. It's strong enough to not have to worry about crushing. Check on the ideas Joe mentioned and see if they apply to your situation. Try the easy things first.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Square drain plate for Tile Redi shower gagler Kitchen & Bath Remodeling 4 08-28-2011 10:51 PM
Drain Tile??? Maybe / Maybe not butchbs1985 Plumbing 0 06-08-2011 10:46 PM
Installing french drain / weeping tile Troglodyte Landscaping & Lawn Care 0 05-12-2011 09:33 PM
Interior Basement Waterproofing Approaches - WaterGuard Vs. Schedule 40 Drain tile sconley Building & Construction 6 05-04-2011 11:03 AM
How to Finish Tile Floor around Drain Hole atm Tiling, ceramics, marble 3 09-12-2009 11:39 AM
