Drain Stand Pipe Adding Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-11-2011, 01:56 AM   #1
drain stand pipe adding sink
Hello all, I'm wanting to add a sink to this drain pipe that is for the washer. I would assume there is a ptrap under the Slab? Is it possible to add a sink to this? what would need to be done. Would this need to be vented as well? This would be just like a utility sink which would have a ptrap under the sink.
myers77 is offline   Reply With Quote
Old 04-11-2011, 04:13 PM   #2
I looked down pipe water sitting at very bottom. Would that mean there is a ptrap then?
Old 04-11-2011, 09:04 PM   #3
If you see standing water, then should mean there's a P trap there. Just for additional confirmation I'd suggest pouring a bucket of water down the stand pipe, then look for standing water again.
VIPlumber is offline   Reply With Quote
Old 04-11-2011, 09:25 PM   #4
That worked so how would I go about installing a sink to this?
Old 04-12-2011, 10:46 PM   #5
Cut it down to proper height and add laundry tub w/ P trap over top. Just let laundry discharge into tub and you're good to go.
Old 04-12-2011, 11:10 PM   #6
Can I add like a y to the top and have the washer drain into one part so I don't have the washer going into laundry tub since the sink will be about a foot to the left
Old 04-13-2011, 02:44 PM   #7
Sure, that'd be fine.
Old 04-14-2011, 09:02 PM   #8
Thanks a lot
Sink drain leaking, question bergerdude Plumbing 3 03-27-2011 12:43 PM
Basement - Tub & Sink drain SnoSheriff Plumbing 2 02-05-2011 06:34 PM
Rerouted Under Sink Drain for Disposer gilbo125 Plumbing 5 01-24-2011 08:35 PM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 09:11 PM
Drain for an "Outdoor Kitchen" Sink Rich Plumbing 5 08-26-2006 06:48 AM
