Drain Snake BROKE - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-14-2011, 12:21 AM   #1
Question
drain snake BROKE off in drain !!
my plastic drain snake broke off in my bathtub drain pipe how do i get it out ??? my tub will not drain !!
Last edited by Jesicca; 03-14-2011 at 01:56 AM. Reason: accidentally used trademark name in my post
Jesicca is offline   Reply With Quote
Old 03-14-2011, 05:18 AM   #2
Rewards Points: 151
I believe there is a screw in the center of the drain that secures the metal strainer. Did you remove this strainer before using the plastic tool. I would hesitate to call that a drain snake; I might call the manufacturer a snake.
If you can get the strainer off yourself, then if you can reach the broken end of the plastic tool with your finger, you might be able to use a needle nosed plier to reach in and grab it. If that fails, then use a metal snake. Snakes have a spiral end that grabs material causing the clog. The local homecenters have small snakes. Ask the salesperson if he can show you how to properly use the tool.
rjordan393 is offline   Reply With Quote
The Following User Says Thank You to rjordan393 For This Useful Post:
Jesicca (03-15-2011)
Old 03-14-2011, 06:08 AM   #3
Rewards Points: 1,216
You might have to go on the other side of the wall and take the entire drain apart and pull it out from there.
COLDIRON is offline   Reply With Quote
Old 03-14-2011, 10:29 PM   #4
no screw
i looked at the drain and there is no screw to remove the strainer, so therefore i dont believe i will be able to get that snake thingy down there because the holes in my drain strainer are very small, what should i do now take #2 advice and tear down the wall lol
The Following User Says Thank You to Jesicca For This Useful Post:
Nik333 (04-28-2016)
Old 03-15-2011, 05:53 AM   #5
I wouldn't tear down the wall I would look on the other side of the wall and see if there's a access cover.
The Following User Says Thank You to COLDIRON For This Useful Post:
Nik333 (04-28-2016)
Old 03-15-2011, 07:34 AM   #6
peaked at birth
we have "retriever heads" on our larger cables for such problems. Imagine a spring, tightly wound, the head being the same but the spring opening up and expanding a little until it ends with a pointed end than can pierce things...if you run the motor the direction to turn it to do so. A retriever head will snag the item, like your plastic snake and wrap it around itself. But don't continue driving the snake or you might break it off again and retrieve all of it. Stop the retriever snake after a few revolutions and pull it out without turning it. Should come right out.
Since that plastic line is not that far down, you might try this:
You can ask or google but I'm not sure there are small drain retriever heads available. You can easily make one though.
Buy a coiled spring metal snake in a manual winder can..the depot has them. The "Armstrong model".
You can bend the end around to make a hook that will snag the plastic line. You might need to heat the spring metal tip up to get it soft to bend easier.Feed it down the overflow of the tub...after removing the drain lever etc if you have such a mechanism in there. Rotate your snagger as you go down in the snag direction of course so you simply don't push the plastic down further. First try going only as far as the first 8 inches of the plastic...gage that by looking at how much broke off and came out in your hand. Pull back out and see if you grabbed it. Repeat going a bit farther each time.
Eventually, if you do not snag it, you may push it out of the smaller piping into you larger drain pipes. Not so bad because with the barbed ends it might scoot out into the municipal grinders & boosters and eventually feed new species of bacteria.
analyst is offline   Reply With Quote
The Following User Says Thank You to analyst For This Useful Post:
Old 03-15-2011, 08:41 PM   #7
lol i really wish there was an access panel, we live in a trailer and those pipes have been replaced before along with the wall and no one ever put the access panel back, so if it comes down to it unfortunately we will have to tear down the wall, thankfully its a small space and it wont be too much to repair
Old 03-15-2011, 08:57 PM   #8
Rewards Points: 14
If you live in a trailer you should be able to get to the drain line from underneath the trailer.
Hornnumb2 is offline   Reply With Quote
Old 03-15-2011, 09:49 PM   #9
i didn't even think of that i'll crawl up under there tonmorrow and see if it comes out down there if not then i'll try wat the previous guy said and if that don't work bye bye wall
Old 03-16-2011, 06:02 AM   #10
I second that.
Old 03-16-2011, 05:55 PM   #11
ok so i bought some hair clog remover from the depot and it has unclogged the drain, is it extremely important that i get that plastic thing out of there now thats its draining ?????
Old 03-16-2011, 05:57 PM   #12
Learning by Doing
Leah Frances's Avatar
Sorry. But it will cause some problems if you leave it. Lord knows what the drano did to it.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 03-16-2011, 09:36 PM   #13
Homerepairguy's Avatar
Rewards Points: 998
You have received some advice that can work but maybe consider calling a plumber before you make things worse. The broken plastic snake must be removed or you will have ongoing clogging problems, especially from hair catching on the broken snake. The further down you push the broken snake, the harder it will be for the plumber to get it out. Don't use any more drain cleaner before calling the plumber as it will only make his job much harder.
Homerepairguy is offline   Reply With Quote
Old 04-28-2016, 07:43 PM   #14
Rewards Points: 4
Re: drain snake BROKE
Proper tools and experience go a long way...Call a professional.
The Drain Clean is offline   Reply With Quote
Old 04-28-2016, 08:11 PM   #15
Rewards Points: 1,596
Jesicca- are you comfortable with all the plumbing terms they're using? If not, ask. No harm in asking.
Nik333 is online now   Reply With Quote
Broke the Tub Drain Crosspiece, Now What? MrBill_DIY Plumbing 13 05-02-2012 09:28 PM
Bathroom snake will not go down tub drain? AmyR22 Plumbing 3 09-08-2010 10:33 AM
Tub Drain Broke mginani Plumbing 2 01-23-2009 05:48 PM
How to use a snake to clear a drain? Nestor_Kelebay Plumbing 11 12-09-2008 04:45 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
