Drain Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-01-2013, 07:59 AM   #1
Rewards Points: 396
drain question
Hi,
Is it acceptable to tie another fixtures drain into the toilet drain before entering the waste stack or is it more common for each fixture to enter the stack individually?
detroittigerfan is offline   Reply With Quote
Old 09-01-2013, 10:32 AM   #2
Rewards Points: 240
if i understand your question. i have the sink entering right under the toilet. and it works fine. the stack is a ways away.
Fix'n it is offline   Reply With Quote
Old 09-01-2013, 11:33 AM   #3
Rewards Points: 2,240
How far away from the stack is the toilet?
Are the toilet/sink re-vented?
"RF"
rossfingal is online now   Reply With Quote
Old 09-01-2013, 12:43 PM   #4
Rewards Points: 2,104
You would need to vent the sink you tied in.
Old 09-01-2013, 01:31 PM   #5
Rewards Points: 396
not what I asked.
Old 09-01-2013, 01:32 PM   #6
Rewards Points: 396
If your tying a sink drain into the toilet drain before entering the stack and both are within 5 feet of the stack do you still need to run a separate vent for the sink?
Old 09-01-2013, 02:33 PM   #7
YES
Vents are done to prevent trap pull.
Old 09-01-2013, 02:34 PM   #8
not what I asked.
By the way either way you will need to vent it.
Old 09-01-2013, 03:02 PM   #9
Plumber
TheEplumber's Avatar
Rewards Points: 904
not what I asked.
What you asked does not have a yes or no answer.
You have not mentioned what code is used in your area, this will affect how your inspector reviews your work
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
"custom" washer drain using rain downspout- venting question denemante Plumbing 5 02-13-2013 07:56 AM
Center Drain Washine Machine Outlet Box Question Please Help!! joshua.easter Plumbing 9 07-23-2012 08:46 PM
Replacing putty in shower drain, question about drain construction scottyv81 Plumbing 4 03-28-2011 07:43 PM
Existing French Drain Question chrisswany Landscaping & Lawn Care 4 08-17-2010 10:55 AM
