#16 | |
call me E
drain questionQuote:
When posting in forums, letting us know your location will help others give better feedback/advice/solutions to your questions |
| The Following User Says Thank You to TheEplumber For This Useful Post: | plummen (01-26-2013) |
#17 |
Roofmaster
drain question
Do you get a vortex too? Thats a good thing! Drains are supposed to make a sucking sound.
" A lot of men build things, and a lot of things fall down " |
#18 | |
Master General ReEngineer
Yet, You've stated NOTHIN', 'bout how Yer system is set-up.... Personally, I do whatever needs doin', in whatever fashion is needed... |
#19 | |
retired elect/hvac/plumb
If the stack/vent above the top fixture is big enough the lower fixtures can be tied into it above flood range of that fixture without a problem.
"facts" have no relevance to this discusion To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Posting from a concrete bunker under a non descript barn |
| Display Modes | |
| Center Drain Washine Machine Outlet Box Question Please Help!! | joshua.easter | Plumbing | 9 | 07-23-2012 09:46 PM |
| Utility sink drain pipe question | jabergess | Plumbing | 3 | 05-06-2011 09:01 AM |
| Replacing putty in shower drain, question about drain construction | scottyv81 | Plumbing | 4 | 03-28-2011 08:43 PM |
| Existing French Drain Question | chrisswany | Landscaping & Lawn Care | 4 | 08-17-2010 11:55 AM |
| Furnace leak while running AC unit | lbartowski | HVAC | 3 | 09-18-2009 02:46 PM |
