Drain Q: Basement Utility Sink Move From One Side To The Opposite - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-27-2013, 03:25 PM   #16
Always learning...
fetzer85's Avatar
Rewards Points: 262
Originally Posted by fetzer85 View Post
What's that drain in the 2nd pic? Is it also making the 40-50ft run to the main stack?
Ok, back in this post of mine that's all I was asking, if it makes the long run down to your sewer. Just wanted to verify that it couldn't be tied into.
fetzer85 is offline   Reply With Quote
Old 03-27-2013, 03:38 PM   #17
That was my first option to have one of the small sump pump under the sink and pump the drain to that pipe, but I will like to avoid any use of pumps.
amb1s1 is offline   Reply With Quote
Old 03-27-2013, 03:43 PM   #18
Always learning...
fetzer85's Avatar
Rewards Points: 262
Well then I think your idea of elevating it on a platform sufficiently high enough to allow for proper drainage is your best bet.
Old 03-27-2013, 04:51 PM   #19
Roofmaster
Rewards Points: 2,210
No you are not good with the 2 x 6. If you look at my formula you need a 2 x 12 with 3/4 inch plywood. That will give you a quarter inch per foot. Now, I would venture to say that you can get away with less slope since we are not talking about much solid waste, such as that which comes from a toilet. The 2 x 6 with 3/4 inch plywood will give you 1/8 inch per foot. Go with a 2 x 8 box with 3/4 plywood.
Old 03-27-2013, 07:38 PM   #20
Rewards Points: 2,038
What state are you in. It will make a big difference as to which plumbing code applies.
If your in an IPC code state you will need to revent the drain by your new laundry sink location. Use an Air Admittance valve by the laundry tray downstream of the trap for the Laundry tray.
http://www.homedepot.com/p/Oatey-Sur...6#.UVOR0lerV6A
Old 03-28-2013, 11:04 AM   #21
I live in NJ.
Old 03-28-2013, 02:06 PM   #22
Originally Posted by amb1s1 View Post
I live in NJ.
Looks like they follow IPC code then.
leaking drain in utility sink keithy Plumbing 11 10-10-2012 10:01 PM
Can two washers drain into one utility sink? mcru Plumbing 6 07-26-2010 08:23 PM
After Snaking, Basement floor drain and utility sink still Bubbling & Backup bikermark1 Plumbing 2 07-22-2010 12:14 PM
Adding a utility sink in the basement - draining question sbazzle Plumbing 3 04-24-2010 05:59 PM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 09:11 PM
