Drain Problems - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-19-2012, 11:14 AM   #1
Drain problems
Whenever my washing machine or bathtub drains, every drain in the house starts to gargle. The water in the toilets splash up and then is gets lower. If I give the kids a bath let the tub drain and then try to wash a load of clothes water comes out from under the washer as it drains. Help, what can I do to fix this? There is also a smell like dirty sewer water.
Renae1121 is offline   Reply With Quote
Old 08-19-2012, 11:33 AM   #2
Rewards Points: 14,312
Plugged up vent, stopped up main sewer line, or if your on a septic it could be the tank is full or the drain field has failed.
I listed them in order of where to start working and the simplest and cheapest ones first.
Renae1121 (08-28-2012)
Old 08-19-2012, 11:42 AM   #3
Rewards Points: 37
How many levels in your home? What levels are the washer and bathtub on?
Any backup will be seen at the lowest drain in the system.
tvanharp is online now   Reply With Quote
The Following User Says Thank You to tvanharp For This Useful Post:
Old 08-19-2012, 02:44 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 912
If you have water coming from the floor drain in the laundry rm. I'd guess your mainline is plugging.
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 08-20-2012, 06:49 PM   #5
We are in a one story with a non finished basement. The previous homeowners are friends with my patents and said they never had water down there. Well we have had over a foot of water down there several times, and now I can't get it to dry out either.
I'm so over water issues. Thank you for your suggestions. I will work my way down the list.
Very slow drain no drain blues Plumbing 16 04-03-2012 05:39 PM
Setting a new tub! Drain alignment problems crza1 Plumbing 7 02-19-2012 07:05 PM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 10:21 AM
Water heater drain pan - can I drain into the washer drain? cjartguy Plumbing 7 04-15-2009 02:34 PM
