Drain Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-15-2008, 07:42 AM   #1
Drain Plumbing
I have been having a discussion with some other contractors concerning PVC drains.
Using pvc pipe and fittings for a sink drain - there is a concern that the joints as in sleeves etc create areas where debris can collect - is this true? one thought is - the joints were designed, when properly installed, creates a smooth transition inside the pipe.
Your help is most appreciated - or did I bring the great debate to a new level.
Thanks,
HandyMac
HandyMac is offline   Reply With Quote
Old 06-15-2008, 10:15 AM   #2
oops, did I do that!
Versus what? All piping is designed for the best flow results. If you feel that the slight imperfections are going to create clog problems, whether its a sink or not, the question should be...can pvc be so poorly assembled that it creates problems?
I really dont see the debate.
8 Ball is offline   Reply With Quote
Old 06-15-2008, 10:59 AM   #3
whether its metal or plastic, in sink drain, debris is going to collect to some point. I figure more so in a bathroom sink, less water volume then a kitchen sink. I think it really comes down to what you feel more comfortable working with.
DUDE! is offline   Reply With Quote
Old 06-15-2008, 12:27 PM   #4
Unless you run you drains in plastic tubing with no fittings, you are going to have voids where connections are made. This is true with any material. A joint in PVC has less of a void than threaded galvanized pipe.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 06-20-2008, 10:45 AM   #5
you can buy debris traps/caps for pvc pipes from most plumbing stores
bazmanblue is offline   Reply With Quote
"Trap" or canister along bathtub drain plumbing Hushpuppy Plumbing 6 06-30-2011 08:26 AM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
basement bathroom (concrete floor drain plumbing) amakarevic Plumbing 4 11-27-2007 05:37 AM
Washer drain peloncito Appliances 7 08-04-2007 12:56 AM
