Originally Posted by Alan
To the O.P. Typically we put shower valves at 42" so it seems your walls might be a little low for that.... would it be that bad to build them another 6" taller so that the valve can be installed at a standard height?
I considered that....but if you look at the window on the right side of the pic, those walls are at the same level...
Besides, if the walls are too tall, we won't be able to see as much of each other awsome bodies while taking a shower......
But then again....maybe taller walls are not a bad idea......
This is going to take some more thinking......one of my issues is getting the hot and cold to the shower....under that bottom plate at the wall is a 3.5x11.25 PSL beam.....
