Drain Pitch - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-27-2011, 07:03 PM   #1
drain pitch
I am converting a bedroom in my house to a master bath, but the septic and drain field are on the opposite side of the house. I understand that I will have to cut the concrete floor to run my new pipes, but how much pitch should I give it ? Any info to make this project easy will help
mowood is offline   Reply With Quote
Old 06-27-2011, 07:20 PM   #2
the Musigician
DangerMouse's Avatar
I believe it's 1/4" per foot.
DM
Old 06-27-2011, 10:26 PM   #3
^^^ +1 to DM. Min is 1/4" per foot for what you are doing.
VIPlumber is offline   Reply With Quote
Old 06-28-2011, 07:25 AM   #4
Plumb or Die!
1/8" per foot if you use 4" pipe. In Canada, anyways. 1/4" per foot if you use 3" and smaller pipe.
plumber666 is offline   Reply With Quote
Old 06-28-2011, 01:49 PM   #5
Homerepairguy's Avatar
Rewards Points: 998
Just be aware that where the slope of a drain is concerned, more is not better. Too much slope can allow the water to run ahead of the solid waste. The 1/4" per foot is said to be a good slope for drains.
HRG
Homerepairguy is offline   Reply With Quote
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
Water heater drain pan - can I drain into the washer drain? cjartguy Plumbing 7 04-15-2009 02:34 PM
sewer backup and stench jayhill Plumbing 12 08-13-2008 11:06 PM
Washer drain peloncito Appliances 7 08-04-2007 12:56 AM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-22-2006 11:13 PM
