Drain Pipes In Slab - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-04-2010, 12:24 PM   #1
Drain pipes in slab
how deep are drain pipes in the slab typically? Do they run horizontally in the slab, or below the slab and only comes up vertically at the connection point?
I am doing a bathroom remodel and the is charging a lot to do the concrete work. So I'm thinking about renting a jackhammer and doing the trenching myself, but I wanna make sure i don't hit a drain pipe. Any tips on locating the drain pipe without one of those fancy cameras?
acerunner is offline   Reply With Quote
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 12:23 PM
copper sink and standard drain pipes chefnmusic Plumbing 3 10-11-2008 08:18 AM
installing gutter drain pipes john442 Landscaping & Lawn Care 2 04-14-2008 10:33 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
Where to find 2" square plastic drain pipes The_Flash Roofing/Siding 4 07-25-2005 07:35 AM
