Drain Pipe Turns - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-20-2014, 03:05 PM   #1
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 384
Drain Pipe Turns
I was at one of my customers job sites and saw these drain pipes in the floor and was wondering how they passed inspection. I thought after 135*, a clean out was required. Tis has 360* of turns.
Just posting this for my own knowledge. What happens on a job site, stays on a job site.
This is a restaurant BTW.
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is offline   Reply With Quote
Old 07-20-2014, 04:33 PM   #2
Rewards Points: 396
It wouldn't pass my inspection because of the short radius 90s much less the other screw ups. And I ain't even a plumber, just plumbed a lot of pipe better than that.
SeniorSitizen is offline   Reply With Quote
The Following User Says Thank You to SeniorSitizen For This Useful Post:
123pugsy (07-20-2014)
Old 07-20-2014, 04:41 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 348
135* is Upc. I cant speak for other codes.
We use "combination waste & vent" when traps are too far for conventional venting methods....
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 07-20-2014, 09:51 PM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 984
The change in direction would usually apply to a main not a branch arm, and yes those turns are extremely short would not pass under my code, that whole set up looks fishy. looks like some of it may end up in the slab.??
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 07-20-2014, 11:31 PM   #5
Rewards Points: 1,684
That is Canada so I have no clue what your doing there.
Old 07-21-2014, 12:02 AM   #6
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,376
Pugzy..... Ya got indoor plumbing up there now
MTN REMODEL LLC is online now   Reply With Quote
Old 07-21-2014, 04:52 AM   #7
123pugsy's Avatar
Rewards Points: 384
Yep.
It just came in this year.
The Following User Says Thank You to 123pugsy For This Useful Post:
MTN REMODEL LLC (07-21-2014)
Old 07-21-2014, 04:56 AM   #8
123pugsy's Avatar
Rewards Points: 384
Looks to be just below.
Is it not supposed to be embedded in the concrete?
Old 07-21-2014, 06:24 PM   #9
Looks like you hired day laborers from your local supply store. I can't think of another way to say it.
The Following User Says Thank You to Ghostmaker For This Useful Post:
Old 07-21-2014, 08:36 PM   #10
123pugsy's Avatar
Rewards Points: 384
Not me.
This is not one of those"it happened to my friend" stories, ha.
Just checking if I pegged something that wasn't done right and I believe it's not. It passed inspection though some how.
Old 07-21-2014, 08:58 PM   #11
Plumber
Rewards Points: 348
What are those black things? Backflow valves?
Old 07-21-2014, 09:28 PM   #12
123pugsy's Avatar
Rewards Points: 384
I have no idea.
Old 07-21-2014, 11:02 PM   #13
I think that may be where they buried Jimmy Hoffa......
Old 07-22-2014, 01:05 PM   #14
Rewards Points: 275
They look like back water valves. Stop waste water from coming back.
ct18 is offline   Reply With Quote
Old 07-23-2014, 10:43 AM   #15
landfillwizard's Avatar
Rewards Points: 498
I am curious to find out why they poured the floor then cut out for the plumbing? Or is this plumbing to fix problems?
landfillwizard is offline   Reply With Quote
Possible to join PVC drain pipe to old iron pipe? darsunt Plumbing 7 03-01-2014 02:53 PM
Sand in the drain pipe om221 Plumbing 0 10-08-2012 03:55 PM
Replacement of existing drain pipe from Kitchen and dishwasher RogerM Plumbing 1 10-13-2011 02:48 PM
drain pipe from HVAC in attic dripping on to sheetrock gnostic19 HVAC 7 03-22-2011 04:05 PM
New bathroom drain pipe leaks PAK Plumbing 2 07-29-2008 10:36 AM
