Drain Pipe Too High For Disposal - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-12-2011, 11:09 PM   #1
drain pipe too high for disposal
Folks,
I'm trying to put in a new disposal to my kitchen sink. It turns out the existing drain pipe to the sewer is not so low, such that if I put in the disposal, the outlet from the disposal would be barely higher (<1/4 in.) than the drain pipe. Sounds like a problem, isn't it? If I am to lower the drain pipe, I may have to cut open the dry wall to take a look...major work. Any idea or suggestion?
Thanks in advance!
Chris
DIY_M14 is offline   Reply With Quote
Old 07-12-2011, 11:25 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 542
Before you open the wall (it may come to that) can you post a good picture? Theres some creative guys here that will have some ideas.
Old 07-12-2011, 11:52 PM   #3
fair enough. here comes a picture
Old 07-13-2011, 12:03 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Any chance the other side of the sink is shallower?
If not, I fear you might be S.O.L.
I see ... . . ... sheetrock repair . . . . . . it's in your future. . . .
Journeyman Plumber
Old 07-13-2011, 12:51 AM   #5
sink is pretty much fixed...one option I was thinking is to give up this best-rated (but bulky) disposal for a smaller one with a shorted height between the sink and the disposal outlet.
Old 07-13-2011, 06:11 PM   #6
Lightfoot's Avatar
Rewards Points: 272
Is the sink a double pan? same depth each side? If not, you can buy sinks with a shallow/smaller side. Maybe you could change the sink to one like that and put the disposal on the shallow side. I think i'd be more willing to do that than to tear out the drywall and start re-arranging the plumbing. but that's just me-seems like the lesser of two evils (and the fact that i hate drywall work). Plus-wifey gets a new sink, and while you're at it, get her the faucet of her choice. When mama's happy, everybody is happy.
(sorry Alan, i didn't read your post until after i typed this)
Lightfoot is offline   Reply With Quote
Old 07-13-2011, 06:28 PM   #7
Plumb or Die!
If I'm reading this right, your disposal outlet is 1/4" higher? Then what's the problem? A drain should have a quarter inch per foot slope. You're within a foot of the drain coming out of the wall.
plumber666 is offline   Reply With Quote
Old 07-13-2011, 06:31 PM   #8
Rewards Points: 1,578
As Plumber666 said, it may work as is.
Otherwise, I'd cut the drywall and see if you can lower the bit coming out of the wall. Depending on what you may find, it may be easier in the long-run.
bob22 is offline   Reply With Quote
Old 07-13-2011, 07:38 PM   #9
Plumber
Rewards Points: 542
If you use a solvent weld trap, you can prolly make it.
Old 07-14-2011, 01:14 AM   #10
thanks for all the suggestions!!
If 1/4''/ft slope is all needed, it might work as is. Will go ahead and do it.
Old 07-14-2011, 06:17 AM   #11
Rewards Points: 1,216
Looks like most of the job is done finish it and see what happens you can always remove the piping and lower it if need be. Go for it.
COLDIRON is offline   Reply With Quote
Old 07-15-2011, 07:34 AM   #12
Plumb or Die!
How'd it go?
drain pipe from HVAC in attic dripping on to sheetrock gnostic19 HVAC 7 03-22-2011 03:05 PM
minimum drain pipe for bathroom sink to code Lindy_B Plumbing 0 02-17-2011 09:34 PM
drain freezing from high efficeincy furnance brokenknee Plumbing 4 12-21-2008 08:26 PM
Drain Pipe MrMrsSip Plumbing 2 11-21-2008 05:46 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
