Drain Pipe Slips Off Tail Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-04-2011, 10:41 AM   #1
drain pipe slips off tail pipe
The kitchen we have had been renovated prior to our moving in. The kitchen sink sits in a corner of the counter. It was placed there so the drain pipes could reach the drain. It is about a 1 foot run from the bottom of the sink to the drain pipe. What has happened is that the pipe attached to the tail pipe is slipping off the pipe even when the nut is tight. What can I do to prevent the pipe from slipping?
tomad51 is offline   Reply With Quote
Old 07-04-2011, 10:46 AM   #2
DIY staff
Rewards Points: 7,174
Put in a new nylon washer and use a new nut----Take a picture---there is more wrong there than just a bad washer.---Mike---
tomad51 (07-04-2011)
Old 07-04-2011, 10:52 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
The tail piece may not be long enough, it should extend at least an inch into the trap. If it does not, get a new one. They come as long as 12" but you can shorten to your requirements.
Coastal South Carolina
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
Old 07-04-2011, 11:03 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Seen before where the pipe coming out of the floor is out of plumb, leaning TOWARD the sink, which causes it to go downhill just a bit, and puts just enough pressure on that slip joint that it will continually fall off.
I've strapped the pipe to the wall with plumbers tape before to alleviate this problem cheaply.
The other possibility is too short a talipiece, which would mean you need new under-sink plumbing parts in which case, you might as well replace it all since you'll have it apart.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
Old 07-04-2011, 02:06 PM   #5
A longer tail pipe sounds like the best solution.
Possible to join PVC drain pipe to old iron pipe? darsunt Plumbing 7 03-01-2014 01:53 PM
framing around drain pipe in basement griffinst Carpentry 5 03-25-2011 06:34 AM
drain pipe from HVAC in attic dripping on to sheetrock gnostic19 HVAC 7 03-22-2011 03:05 PM
Replacing corroded metail drain pipe gschulte Plumbing 2 09-19-2010 08:21 PM
How to unclog condensation drain pipe in attic rpguy4 HVAC 6 06-05-2010 01:07 PM
