#1 |
Drain pipe size for roll in shower
I am having a home built and need a roll in shower for my disabled adult child. The plumber seems to think a standard drain will do. Years ago I had the bathroom renovated with a roll in shower. The plumber stated that the drain must be larger than a regular stand in shower drain. Roll in showers must drain at a higher rate than regular ones. My plumber at that time is now retired, I sold that house, and I can't get anyone to give me the actual size of the drain pipe for this roll in shower. Thanks for your help.
#2 |
call me E
A shower head gallon per minute output, whether in a roll in shower or regular shower, is the same. I see no need for anything larger then normal. If you purchase a fiberglass ADA unit it will have a standard drain..
When posting in forums, letting us know your location will help others give better feedback/advice/solutions to your questions |
| The Following User Says Thank You to TheEplumber For This Useful Post: | jaydevries (04-06-2012) |
| Display Modes | |
| Need help fixing a plugged shower drain. | aireq | Plumbing | 1 | 08-29-2011 06:37 AM |
| replacing cast iron pipe | davemarz | Plumbing | 1 | 05-20-2011 10:16 PM |
| Shower drain not centered for new fiberglass shower pan | keyboarder | Plumbing | 9 | 12-01-2010 09:30 PM |
| HELP ASAP Relocating Shower Drain In Slab - Drain Pipe Loose | perryj | Plumbing | 5 | 08-20-2010 09:48 PM |
| reducing pipe size for sink drain | bluebee1314 | Plumbing | 5 | 12-02-2007 01:53 PM |
