Drain Pipe Repair - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-27-2013, 07:45 PM   #1
Chewy - Lic. Electrician
drain pipe repair
Ok so first off I apologize If Im In the wrong section, its hard navigating the mobile app for me. But here it is, I have to replace a problem drain pipe that's copper and Its corroded with a hole in it. My question, if I cut out the old copper "Y" where It connects to the main, can I replace it with a pvc "Y" attached to the copper pipe with those rubber boot couplings by code? My reason for concern is because the main is vertical and I would essentially be placing pvc between two sections of copper. Making me concerned with the weight on top of the pvc "Y"
SGC622 is offline   Reply With Quote
Old 04-28-2013, 10:38 AM   #2
PoleCat's Avatar
Rewards Points: 1,646
My first instinct would be to get out the J.B. Weld.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 04-28-2013, 11:19 AM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 990
picture would help.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is online now   Reply With Quote
Old 04-28-2013, 11:25 AM   #4
Old 04-28-2013, 11:37 AM   #5
From the main it starts out 1 1/2 copper then steps down to 1 1/4 copper and enters a 1 1/2 drum trap via a reducer. Then comes out 1 1/2 copper and transistions to 1 1/2 pvc and ties into a 1 1/4 copper drain for the tub
Old 04-28-2013, 11:40 AM   #6
Instead of cutting out the part at the main. I was thinking of coupling on to the 1 1/2 copper coming from the main drain and piping the rest to the tub in 1 1/2 pvc just to make it uniform
Old 04-28-2013, 11:42 AM   #7
Is that acceptable?
Old 04-29-2013, 07:14 AM   #8
PoleCat's Avatar
The garden hose will be more of a code issue. Is that all vent stack from the y up? It is likely secured in place somewhere in the wall. Those rubber couplings are for a pipe to pipe connection and not useful for fittings.
Sand in the drain pipe om221 Plumbing 0 10-08-2012 03:55 PM
replacing washer drain pipe robertkirkland Plumbing 51 08-12-2012 11:21 AM
drain pipe from HVAC in attic dripping on to sheetrock gnostic19 HVAC 7 03-22-2011 04:05 PM
Drain Pipe MrMrsSip Plumbing 2 11-21-2008 06:46 PM
washer drain pipe paydelady Plumbing 3 11-13-2007 01:27 AM
