Old 11-28-2012, 01:44 AM   #1
Drain pipe offset, redo?
I think I might have spent a while under the house for nothing. I thought the new elbow I was putting on hit the hole perfectly. After further inspect its not perfect. The flange that I have the front mounting holes barely if at all hit the floor I'm drilling into. Should I go get another elbow and couple to fit it again or is there a flange with a larger mounting ring that will work? Thanks for your suggestions.
Additional information the floor to the drain is about 1 inch so I need to get a new flange that has a 2 inch neck.
joebanks is offline   Reply With Quote
Old 11-28-2012, 06:50 AM   #2
Items wanted: Time
I hope that helps.
NiNe O is offline   Reply With Quote
Old 11-28-2012, 07:04 AM   #3
Super Moderator
What have you done? It would have been easier to set the flange to the backer and tile around it--to late now---
Show us the flange you have in relation to the hole----you may need to trim back the tile
with an angle grinder and a diamond clipper blade---
or you may need to fill that depression with vinyl cement patch---
Old 11-28-2012, 03:05 PM   #4
The hole isn't a problem. The last bath I did the flange was to the sub floor but you'll get a more flush connection if the flange is on top I the tile. I'm picking up a new flange up tonight and ill see how it works out.
Old 11-28-2012, 05:39 PM   #5
Subfloor cut wrong, tile board cut wrong, tile cut wrong.
Try a search on Google on toilet repair flange, about your only hope at this point.
Old 11-28-2012, 05:52 PM   #6
call me E
TheEplumber's Avatar
All flanges are the same diameter. If it were not so, every toilet base would be different- kinda like putting a Ford rim on a Chevy
Can you screw a block on the under side and fill as Mike suggested?
Old 11-28-2012, 08:48 PM   #7
Exclamation
I do love these helpful comments that just point out what someone else would have done. First the subfloor is original and both the cement board and tile are lined up with it. The flange was attached to the subfloor prior to removal so obviously a new one will work with it. But thanks for your comments ... Sarcastic
Old 11-28-2012, 08:49 PM   #8
Thanks if nothing else works that's what I'll do. Great suggestion.
The Following User Says Thank You to joebanks For This Useful Post:
TheEplumber (11-29-2012)
drain pipe from HVAC in attic dripping on to sheetrock gnostic19 HVAC 7 03-22-2011 04:05 PM
Basement drain pipe "pit" ground water fix. alecmcmahon General Discussion 13 12-01-2010 06:42 AM
Possible to join PVC drain pipe to old iron pipe? darsunt Plumbing 1 07-12-2009 11:46 PM
New bathroom drain pipe leaks PAK Plumbing 2 07-29-2008 10:36 AM
washer drain pipe paydelady Plumbing 3 11-13-2007 01:27 AM
