Drain Pipe Noise - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-12-2010, 01:48 AM   #1
drain pipe noise
Hi,
My parent's bedroom at downstai and there is drain pipe inside the drywall; along with middle of closet, when flush toliet at upstair, the water run through the drain pipe makes lots noise, especailly night time, anyway I can put something inside the drywall to reduce the noise from the pipe? any suggesttion.
Thank you
sid58ney is offline   Reply With Quote
Old 02-12-2010, 06:23 AM   #2
You apparently have PVC drains, and they are usually noisey. You can insulate them after remving the drywall in that stud bay. It should help, but it may not be good enough. A better solution, but expensive, is to replace the PVC with cast iron.
Old 02-12-2010, 08:00 AM   #3
I had a similar problem. I insulated the heck out of them when I was doing some reno work.
kenm09 is offline   Reply With Quote
Old 02-13-2010, 12:25 AM   #4
I put some sound reduce insulated stuff inside the drywall and around the drain pipe, but seems doesn't work well, anything I can do now?
Thank you
Sidney
Drain Pipe about 20 Inches to the right of Vanity Sink mark2741 Plumbing 2 12-16-2009 10:32 AM
closet flange ....over the drain pipe or inside the drain pipe moegumble Plumbing 2 08-18-2009 07:09 AM
Installing Wye to Existing Drain Pipe alladin15 Plumbing 1 08-17-2009 10:23 PM
Vent requirement for laundry washer drain pipe WaldenL Plumbing 9 01-12-2009 07:11 PM
bathtub drain in concrete - tail pipe questions amakarevic Plumbing 7 06-17-2008 09:50 PM
