Drain Pipe Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-09-2011, 05:16 PM   #1
AGF
Question
Drain Pipe Leak
The ABS drain pipe that leads from the kitchen sink through to the basement has 2 vertical cracks in them which I'm guessing has been caused by the drastic change in temperature and lack of proper insulation from the previous owner. I've temorarily put water proof tape that runs vertically on the crack along with some support tape running horizontally to help keep the pipe together. As this may be my first attempt to do the repairs myself and am by no means a plumbing expert, I'm wondering what the best course of action will be to replace these two pipes and the elbow that attaches them both. The white residue on the upper pipe shows where the crack is in the middle of that pipe. See pictures for additional details. Any suggestions on how to fix or how I can reduce the cost from an expensive plumber would be helpful. Thanks!
AGF is offline   Reply With Quote
Old 02-10-2011, 05:29 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,728
Ayuh,... It looks like it might a Froze, 'n split...
Anyways,...
Just cut it off at either end, 'n glue in new pieces from a boxstore, pretty much exactly as it is Now...
Totally replace whatever ya cut out with New, tubing, 'n fittings...
Glue, primer, a saw, 'n sandpaper should be about All ya need toolwise...
Bondo is online now   Reply With Quote
Old 02-10-2011, 07:13 PM   #3
Be sure not to redo it in ABS. Try it in PVC and use fernco style couplings to attach to the abs. Doubt it split from cold unless u have a stoppage there shouldn't be any expansion from cold. It's just an unfortunate side effect of abs pipe. Its very weak. Hot water will warp it.
RooterRuss is offline   Reply With Quote
Old 02-10-2011, 07:17 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 904
Why do you say its very weak?
Old 02-10-2011, 08:07 PM   #5
I had a feeling someone might disagree with me on this. Just hold abs in one hand and PVC in another. Properly hung abs still sags, the weight of the ground ovals the pipe and causes a crack on the bottom. I don't like it, I don't use it. In fact it makes me a lot of money. U may not be disagreeing with me I just know some people like it, I just don't understand why
Old 02-25-2011, 07:58 PM   #6
This looks like a 3" or 4" line that probably receives more than just the sinks. Is it a vent line also? If it's not supported properly(strapped) and this vents thru the roof, the weight could put to much torque at those bends. Any impact to the unprotected pipe coiuld cause the fracture. i agree with the other gentleman that the pipe should not hold water to freeze. Make sure that line is clear before you continue.
diggerman is offline   Reply With Quote
Tags
abs , drain line , leaking pipe
Toilet Flange Inside or Outside Drain Pipe? sledged Plumbing 23 01-18-2012 12:18 PM
removing Cast Iron drain pipe jimmyfloyd Plumbing 1 01-04-2011 03:47 PM
I need Help Real Bad!! Drain Leak in Tub... harryjay97 Plumbing 7 12-10-2010 04:33 PM
Water Pipe Leak in Backyard diginside Plumbing 2 07-08-2010 04:50 PM
Drain Pipe MrMrsSip Plumbing 2 11-21-2008 05:46 PM
