Drain Pipe Cracked Lengthwise In Middle - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-19-2012, 10:41 PM   #1
Rewards Points: 1,418
Just curious.
What would cause a vertical section of 4" cast iron drain pipe to develop a single crack lengthwise for about two feet in the middle (not all the way to either end)?
The pipe is over 70 years old. The area (building interior) never got below freezing.
Does cast iron occasionally have stresses from manufacturing that cause it to suddenly and unpredictably crack?
Old 02-19-2012, 10:55 PM   #2
Rewards Points: 616
i have ran new cast in commercial setting and when we pressure tested it would not hold and found a crack in center of pipe before talk about frustrating over 500 feet of cast
jaydevries is offline   Reply With Quote
Old 02-19-2012, 11:18 PM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
It happens,I replaced around 20' of 4" last week that was exposed to tie in some ground work for a new bathroom with a crack like that in a 3' section of it so we went ahead and replaced it all while we were there
Cast iron usually gets eaten up from the inside out,so it may be pretty thin in that area when you open it up
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Possible to join PVC drain pipe to old iron pipe? darsunt Plumbing 7 03-01-2014 02:53 PM
Toilet Flange Inside or Outside Drain Pipe? sledged Plumbing 23 01-18-2012 01:18 PM
How to prepare toilet drain pipe for toilet flange? brett.c.brown Plumbing 11 12-15-2011 08:41 PM
drain pipe from HVAC in attic dripping on to sheetrock gnostic19 HVAC 7 03-22-2011 04:05 PM
Basement drain pipe "pit" ground water fix. alecmcmahon General DIY Discussions 13 12-01-2010 06:42 AM
