Drain Pipe Cap Removal - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-26-2010, 11:15 PM   #1
jho
jho's Avatar
Drain pipe cap removal
I'm finishing the bar in my basement, and the previous owner has the drain pipe that comes out of the wall capped off. The cap is threaded on and it is not budging when I wrench on it. I'm using two pipe wrenches, one to stabilize the pipe and the other to wrench on the cap. I used all my might, and it's not budging one bit. Do any of you have any suggestions of what I can do to get this cap off? Can I heat it up? I'm afraid to knock it with a hammer, I'm thinking that might possibly mess up the threads. I'm all ears. Here are some pics so you can see what I'm dealing with. The pipe is 1-1/2 diameter galvanized, if that helps any.
And here's a picture of my bar, for shats and gaggles. I just finished the addition off to the left last night, took me 4 hours to build that.
jho is offline   Reply With Quote
Old 05-26-2010, 11:31 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
how much access to the fitting inside the wall do you have? If it's a screw fitting and not leaded, you might have an easier time unthreading the whole nipple and then using a MIP X FEMALE SOLVENT ABS ADAPTER.
Besides, it's better to eliminate as much galvanized as you can before it rots out, and breaks off at the threads.
If you can't get it that way it looks like you might need a couple of bigger wrenches..... a pair of 14" pipe wrenches might do it, but i'd go bigger just for good measure.
Journeyman Plumber
Old 05-26-2010, 11:53 PM   #3
jho
jho's Avatar
Sorry Alan, I should have specified that I haven't had much experience with plumbing, so I don't know much of the lingo. I'm not too sure what an MIP X FEMALE SOLVENT ABS ADAPTER is? I googled it, and I'm thinking this is kind of what you're talking about:
If that is what you're referring to, that is the direction I plan to take, converting over to PVC. I'm including a picture of the pipe coming out of the wall. Might give you a better understanding of what I'm dealing with. Thanks for the help, too, btw.
Old 05-27-2010, 12:56 AM   #4
Doing it myself
Alan's Avatar
You're close. That's an FIP X FEMALE SOLVENT ADAPTER
You want male threads on it so that it will thread into the fitting.... The fitting is threaded, right? Check that first before you try tweaking the nipple, because you don't want to mess up the lead joint...
Journeyman Plumber
Old 05-27-2010, 08:52 AM   #5
Rewards Points: 1,216
Use 2 bigger pipe wrenches, get rid of the channel locks you can not get enough grip with the channels.
COLDIRON is offline   Reply With Quote
Old 05-27-2010, 11:16 AM   #6
jho
jho's Avatar
Would you recommend I use a torch to heat it up in case it's rusted on? That's what my friends are recommending, but I don't think they're "qualified" to give me that kind of advice.
Old 05-27-2010, 11:45 AM   #7
I would try heating it and if that didn't work I would cut it off with a hack saw and use fernco fittings purchased at HD or Ls.
They are rubber with clamps in case you didn't know.
Old 05-27-2010, 11:48 AM   #8
jho
jho's Avatar
Ah perfect! Yeah, if I can't get that off, then I'll just take that route.
Is that ok for joining the galvanized with PVC piping, too?
Old 05-27-2010, 05:21 PM   #9
Think so not sure.. if it's the same diameter shouldn't be a problem.
Maybe someone else knows for sure.
If it was mine I would do it if I couldn't get the cap off.
OH OH just thought of something if you hack saw it off and you can't connect to PVC you can buy a small nipple same size cut the threads off 1 end and clamp the nipple then buy a PVC female to glue fitting for the other end then run your PVC out from there.. but I think you can just clamp the PVC.
Old 05-27-2010, 06:08 PM   #10
You allways need 2 pipe wrenches.Using one and a channel lock ain't gonna cut it.People will talk about you,at your own bar while your serving them.
bluejeans is offline   Reply With Quote
Old 05-27-2010, 06:19 PM   #11
Civil Engineer
Rewards Points: 4,572
That galvanized fitting looks like it is in pretty good shape, should come off with a pair of pipe wrenches, but for good measure you can add a persuader to the pipe wrench you are using to remove the fitting. My persuader is a 3 foot long steel pipe that fits over the wrench handle, if you can't remove it with that, there is no hope.
Daniel Holzman is online now   Reply With Quote
Old 05-27-2010, 06:58 PM   #12
Rewards Points: 266
Failing getting the cap off, hacksaw it off (a recip. saw with a metal blade will make short work of it) and join PVC using the Fernco hubless coupler mentioned above.
Jim F is offline   Reply With Quote
Old 05-27-2010, 07:07 PM   #13
jho
jho's Avatar
Can I take a grinder to the pipe rather than using a hacksaw, if it comes down to needing to hack it off, that is? Just curious
Old 05-27-2010, 07:35 PM   #14
firehawkmph's Avatar
Rewards Points: 1,824
Jho,
Borrow another big pipe wrench and show that pipe who's boss. Give it a shot of penetrating oil on the threads. Don't let that pipe get the better of you.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 05-27-2010, 07:38 PM   #15
jho
jho's Avatar
Originally Posted by firehawkmph View Post
Jho,
Mike Hawkins
haha thanks Mike for the encouragement. I'm heading down to give it a shot. I returned the channel locks to get an 18" wrench. I'm going to give it another shot. Thanks guys! I'll let you know how it goes
Basement drain pipe "pit" ground water fix. alecmcmahon General DIY Discussions 13 12-01-2010 06:42 AM
AC Coil drain pipe questions fritzycat1 HVAC 14 11-12-2010 04:51 PM
shower drain removal andrewc1414 Plumbing 0 05-05-2010 12:54 AM
Removal of Bathtub Drain joe3534 Plumbing 4 10-22-2009 09:41 PM
Sink drain for new sink. Can't get to plain pipe. rogersmithiii Plumbing 2 07-10-2009 11:24 AM
