Drain Pipe About 20 Inches To The Right Of Vanity Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-16-2009, 09:30 AM   #1
Drain Pipe about 20 Inches to the right of Vanity Sink
I want to replace a 48" bathroom vanity and sink. The original vanity/sink was installed when the house was built back in 1970, and is very short in height (great for my little kids, but not so much for everyone else).
The sink sits into the right-hand side of the vanity counter, and directly below it, coming out of the floor, are the two water supply lines and a drain pipe.
A trip to Home Depot and Lowes yesterday reveals that the only stock vanity countertops all have the sink placement in the center. And to add to this, the right-hand side of each of the stock cabinets all have drawers (3 of them, vertical) on the right-hand side where the existing drain pipe is.
So, is the solution to cut the drain pipe down to just a 'stub' (a few inches from the floor) and then route PVC pipe, just a few inches above the floor and to the left to get to the center of the vanity and then up to where the sink is?
I'm no plumber obviously. I've sweated some angle valves and changed out the other vanitys in my house without problem though.
I want to do this 'right' but as inexpensively as possible, because I'm selling the house soon.
mark2741 is offline   Reply With Quote
Old 12-16-2009, 09:56 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,354
Ayuh,... Do what ya gotta do, with PVC...
It's Cheap, Easy,+ code compliant...
Old 12-16-2009, 10:32 AM   #3
Rewards Points: 1,010
Yes, it is common in commercial work, where piping locations are often constrained by complications of the building structure, to run pipe in the toe-kicks under cabinets or in the rear portion of cabinets. The latter may require shortening of the drawers.
A second alternative may be custom cabs. Depending on a variety of things, a cabinet shop may be "in the ball park", or much more expensive than the junk you're going to buy from the big boxes
Anti-wingnut is offline   Reply With Quote
Venting ponch37300 Plumbing 41 02-23-2013 10:37 PM
Sink Drain Stopper Won't Pop Up erclark Plumbing 7 07-11-2009 07:31 AM
clogged pipe or trap issue? windowguy Plumbing 3 05-10-2009 10:10 AM
sewer backup and stench jayhill Plumbing 12 08-13-2008 11:06 PM
washer drain pipe paydelady Plumbing 3 11-13-2007 12:27 AM
