Old 11-20-2008, 09:52 PM   #1
Default Drain Pipe
Hi,
Mr Sip has occasionally had to rent a medium duty electric auger to clear the toilet drain. He went from outside thru the 4" cleanout pipe in and also taken the toilet stool up and went from inside to outside. The last time he did this we suceeded in opening the clog but the water flow wasn't as near good as should be. What got our attention is we saw thru both cleanouts that the toilet water was flowing thru both outside drain pipes. Before this the bathtub and sink drained thru one pipe and the toilet thru another line. We wonder what happened there. Any ideas?
Since we did not get the water flowing thru very well we knew we were going to be tackling it again soon. Well today we are back at it. The 3/8" cable with an end knife is now stuck in the pipe. It won't move one way or the other, just kinks the cable. We waited a 1/2 hour or so hoping it would relax but did not. Any suggestions?
Our drain pipe is clay pipe. Seems we heard once that you could place new pipe inside old pipe and let the old pipe collaspe in time instead of digging up the whole place. Anyone heard of that? I guess it may not work for us though because we are on a slab. Wonder if we could just cut out the section of slab we need and repour the concrete?
Thanks Mrs Sip.
MrMrsSip is offline   Reply With Quote
Old 11-21-2008, 01:32 PM   #2
There are now companies that do "trenchless drains". It is a plastic sleeve that is snaked into the existing line. Not sure if it would cure all of your problems since you have two drainlines. This application does not allow for any teeing in the line.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 11-21-2008, 07:46 PM   #3
I go with dragon, the process you refer to is for sewer lines outside of the house where there are no wyes or tee's just a straight shot to your sewer tap, i would chip up the concrete, find the problem area, cut it out, and replace with pvc using two no hub bands.
zosoplumber is offline   Reply With Quote
More On This Topic
We are going to talk a little bit about the toilet flange here and this is where your toilet will sit. This is a 3 inch toilet flange and it ties down into our main 3 inch AVS sewer line and again we have that 1/8 inch fall per foot so that the solids... Read More »
Amidst a drought, most of the country receives little rainwater, if any, these days. When these parched parts of the country do get rained on it is sensible to collect all we can, in order to conserve resources and use it wisely. Follow this article for... Read More »
We are going to talk a little bit about our waste lines and our vent lines right now. The waste line being when you turn the sink on and the water that falls into the sink, where does it go, well it goes right down into this pipe here, travels down the... Read More »
Okay some things you want to look for when you get an colonic is obviously that your therapist wears gloves and that you ask that there is disposable tubing and disposable speculum. Back in the day they used to use metal speculums which you would have to... Read More »
Hi! My name is Cathi Pare with the City of Santa Barbara Water Resource Department speaking to you today for expertvillage.com. We are continuing on our little quest of how to fix the leaks in your toilet. Early, earlier conversation we talked about the... Read More »
Bubbling in toilet rballard Plumbing 11 08-30-2008 09:15 PM
sewer backup and stench jayhill Plumbing 12 08-14-2008 01:06 AM
New bathroom drain pipe leaks PAK Plumbing 2 07-29-2008 11:36 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 05:37 PM
washer drain pipe paydelady Plumbing 3 11-13-2007 02:27 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
