Drain Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-19-2011, 09:25 AM   #16
Originally Posted by TheEplumber View Post
Disassemble the trap, check the mating surfaces of the 90 for imperfections. Coat those surfaces and the trap threads with a then layer of teflon non hardening pipe dope. Reassemble the trap by tightening the 90 first then the flex part. The dope will fill any voids on the mating surfaces and help lube the threads for a little extra turn while tightening.
I think I might have finally figured it out. I put a rubber gasket around the tapered end of the 90, and tightened it to the trap. So far it hasn't leaked in 8 hours. Ran some water through it again this morning, and still didn't notice anything.
ws450r is offline   Reply With Quote
Possible to join PVC drain pipe to old iron pipe? darsunt Plumbing 7 03-01-2014 01:53 PM
drain pipe from HVAC in attic dripping on to sheetrock gnostic19 HVAC 7 03-22-2011 03:05 PM
Replacing corroded metail drain pipe gschulte Plumbing 2 09-19-2010 08:21 PM
Drain Pipe about 20 Inches to the right of Vanity Sink mark2741 Plumbing 2 12-16-2009 10:32 AM
Drain Pipe MrMrsSip Plumbing 2 11-21-2008 05:46 PM
