Drain One Zone Of Baseboards? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-02-2013, 08:00 AM   #1
Rewards Points: 37
Drain one zone of baseboards?
I'm going to post this again in the right forum this time, and with better pictures. I'm trying to drain one zone of hot water baseboards so that I can remove them and eventually have a plumber replace them. I only want to drain this one zone, not the entire system. Can someone let me know what valves I need to close so that I can drain this zone? Thanks!
Drain one zone of baseboards?-valves1.jpg   Drain one zone of baseboards?-valves2.jpg   Drain one zone of baseboards?-fullpicture.jpg
SoxFan44 is offline   Reply With Quote
Old 07-02-2013, 08:23 AM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by SoxFan44 View Post
I'm going to post this again...
I'm trying to drain one zone of hot water baseboards...
Since you're posting on it again... so will I.
Ask your plumber friend to come by and knock this out for you. And to do this work --including removal of the baseboards-- in the best way possible to make the rest of the work that will be getting done later --by him or by you-- work out the best that it can.
Buy him lunch.
hth
The Following User Says Thank You to TarheelTerp For This Useful Post:
Javiles (07-02-2013)
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
can I add baseboards and add zone like this? diy001 HVAC 3 02-04-2012 11:10 AM
3rd zone not working properly MichaelChlopik HVAC 1 10-15-2010 05:59 PM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
