Drain Odor When Using Sink Sprayer - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-13-2009, 12:59 PM   #1
Drain odor when using sink sprayer
I have double kitchen sinks, Drain and traps are clear, however drain emits terrible odor when the sink sprayer is used. Any ideas?
margiedel is offline   Reply With Quote
Old 05-13-2009, 01:24 PM   #2
DIYer
jpsmith's Avatar
Only when the sprayer is used? Might it be that you're spraying hot water into the drain and this is causing more smell to be released than when hot water just runs into the drain without the sprayer?
A good fix for a stinky kitchen drain we've found is to put about 1/2 cup of baking soda in one drain, put the stopper in the other side, then pour two quarts of rapidly boiling water down the drain. The water must be boiling. Baking soda reacts to boiling water similarly to how it reacts with vinegar, but vinegar and baking soda neutralize each other too quickly to do much cleaning work. Repeat for the other side of the sink.
-Jack
jpsmith is offline   Reply With Quote
Old 05-13-2009, 07:22 PM   #3
Long-Time DIYer
Mike Swearingen's Avatar
I just happened to use DrainCare enzyme-based drain cleaner on my kitchen sink drains today for the same problem, along with a sluggish drain.
Works great, too!
Mike
Mike Swearingen is offline   Reply With Quote
Dishwasher Drain - Not by sink jamiedolan Plumbing 2 09-09-2008 11:56 AM
pedestal sink drain stopper not working gernith Plumbing 7 04-18-2008 10:17 PM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 10:11 PM
Drain placement for sink simonb Plumbing 3 09-08-2007 02:08 PM
installing vessel sink drain?! (HELP!) tara Plumbing 2 11-10-2006 01:17 AM
