Drain Location For New Sink Installation - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-12-2010, 10:36 AM   #1
drain location for new sink installation
Is it a violation of code to install a sink drain that passes through a heater plenum? I'm moving my kitchen sink as part of a renovation, and there is a HVAC return plenum made from sheet metal nailed between floor joists where I want to install the drain. I will turn the drainpipe and exit the plenum immediately after penetrating the floor. My alternative is to move the drain about 4 inches forward from the wall, so instead of installing the vertical drain in the wall as normal it will turn vertical in the cabinet under the sink. I have no problem installing the vent line, there is no plenum in that direction.
ductnovice is offline   Reply With Quote
Suspended/Floating sink installation? How? techprincesse Building & Construction 3 11-21-2010 03:05 PM
Maximum distance of sink from drain? DIYHomeTheater Plumbing 0 06-14-2010 07:42 PM
InDirect Drain for Wet Bar Sink? sparkchaser Plumbing 1 04-02-2010 02:52 PM
Sink Drain gonepostal069 Plumbing 2 03-06-2010 10:45 AM
Bathroom Sink Drain (Broken from wall to Ground) bli182nk Plumbing 2 01-11-2009 07:52 PM
