Drain Lines Under Slab - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-25-2013, 01:54 PM   #1
Rewards Points: 276
drain lines under slab
Do you put anything in trench, ie; sand etc. to support drains lines (not supply lines) in a slab foundation?
ugabulldog is offline   Reply With Quote
Old 03-25-2013, 02:47 PM   #2
Rewards Points: 14,306
#57 stone is what I use.
Just using the soil you removed is going to settle over time and the pipes going to move.
Sand is not compressable.
Old 03-25-2013, 03:08 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 904
I use sand or pea gravel- both offer good compaction. Be sure you don't lift the pipe while bedding- it's very easy to do
Old 03-25-2013, 04:05 PM   #4
No disrespect meant but pea grave is rounded and will just move, not what I would use to hold a pipe in place.
Just step on it and it moves and you sink.
Ever seen a pea stone driveway? There's a reason why it's not used for that.
Works fine for landscaping but that's about it.
Old 03-25-2013, 04:20 PM   #5
Plumber
Rewards Points: 904
To each his own Joe- but its the flavor of the day around here. Delivered right to the ditch line in a mixer from the batch plant if you want it that way.
We also use fines from the pit if you want something sandy.
The Following User Says Thank You to TheEplumber For This Useful Post:
jaydevries (03-25-2013)
Old 03-25-2013, 10:53 PM   #6
Master Plumber
Javiles's Avatar
Rewards Points: 996
Down here we use sand or clean fill, pea rock outside the foundation only, mainly in the lats.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Plug water lines in cement slab. Dennis1188 Plumbing 1 10-21-2010 11:17 AM
Basement *VENTING* AND running entire new drain lines. 57_Hemi Plumbing 6 09-30-2010 09:00 PM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 10:21 AM
Who jackhammers the slab when installing drain? tpagel Plumbing 5 09-08-2010 09:27 PM
Crossing Drain lines bdaub Plumbing 1 05-28-2010 02:55 PM
