Old 04-07-2012, 12:28 AM   #1
Drain Length Before Vent?
I am in the process of finishing by basement, the builder had roughed in a bathroom during construction, however it is in the wrong place for my plans. The toilet is in the right spot but I have had to move/add a shower.
My question is:
How far can a shower drain(2") run before it hits the vent? Also this vent is a wet vent (sink drain), is this acceptable?
Attached is an image of the bathroom as it stands now, pipe is not glued just test fit. Also not drawn is the vent for the sink (as i assume ~8' is to far without a vent)
Beley is offline   Reply With Quote
Old 04-07-2012, 12:41 AM   #2
Doing it myself
Alan's Avatar
By my plumbing code, the drainage for that sink would not fly.
Due to it being wet-vented, you are limited to vertical drainage only, which means your trap arm in excess of 90* is no longer a trap arm and is considered horizontal drainage which you have obviously figured out already taking into consideration your assumption that 8' is too far without a vent.
You need to run the drain for the lavatory under the concrete.
Journeyman Plumber
Old 04-07-2012, 02:02 AM   #3
Originally Posted by Alan View Post
...Due to it being wet-vented, you are limited to vertical drainage only, which means your trap arm in excess of 90* is no longer a trap ....
By "vertical drainage only" is that only before it hits the vent?
I have drawn on a different angle to show how i had planed to plumb the sink. I have it going about 18" horizontally after the trap, then it meets the vent and drops about 10" then runs horizontally through the wall.
Old 04-07-2012, 12:49 PM   #4
Doing it myself
Alan's Avatar
By vertical drainage only, that means no horizontal drainage before it dumps into the toilet vent.
Journeyman Plumber
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 11:53 PM
New Roof marknok Roofing 4 08-06-2011 12:41 PM
Need to close off or move a vent pipe & drain that goes to nothing mystic_cobra Plumbing 2 04-18-2011 09:14 PM
Vent directly between trap and drain, or not? wvphysics Plumbing 17 07-18-2010 05:37 PM
sewer backup and stench jayhill Plumbing 12 08-14-2008 12:06 AM
