Drain Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-19-2010, 07:29 PM   #1
Drain leak
Is there a liquid leak-stop that will work on a toilet drain. I believe the leak is coming from a joint where it goes into the main line. Unforturnately, this is a 2nd floor toilet and the only way to get to the pipe it to remove our kitchen cabinets
ACampbell is offline   Reply With Quote
Old 09-19-2010, 09:17 PM   #2
just remove them then
the_man is offline   Reply With Quote
Old 09-19-2010, 09:27 PM   #3
That's what I was afraid of...
Old 09-19-2010, 09:30 PM   #4
yea, it sucks but its what has to happen. Try to open the walls around, leave the cabinets on for now. It might be tougher, but try to get it fixed without pulling them. 8 years in the trade, I've only ever pulled one upper cabinet, no lowers. I've always found a way to work around em
Tub drain leak? kcrossley2 Plumbing 3 01-19-2010 12:47 AM
Drain Leak Causing Slab Problems? Texas Toast Plumbing 1 09-22-2009 10:37 AM
Washer on/off drain leak opper3 Plumbing 1 03-02-2009 06:06 AM
Kitchen drain leak hullabaloo2 Plumbing 4 09-02-2008 07:25 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
