Forums | Home Repair | Home Improvement | Painting | Interior Decorating | Remodeling | Landscaping
Old 07-05-2010, 04:46 PM   #1
Share |
Drain leak?
Hi, Guys. I have a rent house with a crawl space, and the tenant informed me that water was running out the bottom of the house through the crawl space access. I went by the house yesterday and could not see if any of the drain pipes were disconnected without crawling under the house. There is a lot of water and it seems to be coming from the toilet. I flushed it several times and noticed the water draining from under the house. Initially I thought the drain to the toilet had become disconnected, but the renter is having problems with the toilet flushing. It flushes rather slow which would contradict the line being disconnected. Any thoughts? The house is 70 miles away, and I am planning to go there tomorrow to determine if I can fix it or if I need to call a plumber. Thankyou.
jeruss is offline   Reply With Quote
Old 07-05-2010, 05:08 PM   #2
Owner
LateralConcepts's Avatar
Drain leak?
There is a blockage in the main line. When it backs up, the water is either leaking from a broken pipe or over the top of the closet flange
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
LateralConcepts is offline   Reply With Quote
Old 07-06-2010, 11:20 AM   #3
Drain leak?
better bring a pump, large tarp to crawl on and some lights if you want to see where it is coming from
plumberinlaw is offline   Reply With Quote
Tub drain leak? kcrossley2 Plumbing 3 01-18-2010 11:47 PM
Drain Leak Causing Slab Problems? Texas Toast Plumbing 1 09-22-2009 09:37 AM
Washer on/off drain leak opper3 Plumbing 1 03-02-2009 05:06 AM
Kitchen drain leak hullabaloo2 Plumbing 4 09-02-2008 06:25 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
