Is This Drain Layout Ok? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-24-2010, 05:35 PM   #1
Is this drain layout ok?
I am installing a bathroom in the basement. I want to make sure the the path and sizing are ok, or if I'm missing anything. Thanks.
The drawing is not exactly to scale.
this was drawn on some scratch paper, please excuse the text coming through the background.
acerunner is offline   Reply With Quote
Old 10-24-2010, 06:59 PM   #2
In my area, the low heel 90 for the wc vent is illegal. Not sure about san fran, but I would use the drain line you have for the sink as my vent, and wet vent my sink into it. If you can do this, just make sure the invert of the 2" wye is above the center line of the 4" drain line.
the_man is offline   Reply With Quote
Old 10-24-2010, 08:44 PM   #3
so use the sink drain as wet vent? would i need to upsize it?
In this setup, can the shower also be wet vented through the sink drain too?
another concern was whether i needed any cleanouts.
Old 10-24-2010, 10:29 PM   #4
not sure about cali, i'm in the upc (which i think is what cali code is or is based on) trap arm length on 2" pipe is 5 feet. You could wet vent them all, but would probably require some modifications to your layout. I would leave it the way you have it and just run one less vent line. I'd put a cleanout on the wet vent line below the sink tie in, don't worry about it on the shower vent.
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 10:56 PM
Condensor drain Captflx HVAC 6 08-17-2008 10:19 AM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
