Drain King Vs Snake - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-20-2013, 08:25 PM   #1
Rewards Points: 119
Drain king vs Snake
Suppose that you have a tub or bathroom sink that is not draining as fast it should. What is better to use, a drain king or a snake? Mostly you hear people saying that they called a plumber to snake their drain but if a drain king is as effective you can open a bathroom or kitchen window and for $15 do it yourself. Does a drain king risk breaking a pipe more than a plumbing snake?
I have a tub and a sink that are not draining properly (same bathroom) and wondering what is my best course of action.
And what should be done regularly to improve? Anything non-chemical to pour down the drains to keep things orderly? I have heard vinegar and baking soda and hot water? Thanks.
SpaceCoast is offline   Reply With Quote
Old 11-20-2013, 10:29 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
What is a drain king?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 11-20-2013, 11:40 PM   #3
Rewards Points: 352
Pressure bag
drain kings are cheap,go ahead and try it. Let us know how it works
plumberinlaw is offline   Reply With Quote
Old 11-21-2013, 12:06 AM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 984
water under pressure on drain pipe put together with slip nut joints ??????
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 11-21-2013, 12:22 AM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 352
I had to google it I call it a blow bag
A blow bag will push water up the vent or tub overflow
The Following User Says Thank You to TheEplumber For This Useful Post:
plummen (11-21-2013)
Old 11-21-2013, 09:59 AM   #6
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
If it is mainly hair clogs, google Zip-it drain cleaning tool.
It's sorta gross to do, but it's cheap, reusable, chemical free, and does a great job of getting hair clogs out of drains.
use a sewer snake to clean shower drain laurapet50 Plumbing 16 12-22-2012 12:39 PM
Cast drain backup dcj710 Plumbing 6 09-20-2012 11:24 AM
New Drain and Overflow assembly not fitting properly to new tub - Help plz amodoko Plumbing 19 12-21-2011 03:28 AM
drill powered 1/4" snake, bathtub drain Yoyizit Plumbing 10 07-20-2010 11:35 PM
relocating washer drain idodishez Plumbing 7 04-21-2009 09:36 PM
