Drain Issue Please Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-10-2009, 02:18 PM   #1
Question
Drain issue Please Help
The main drain/sewer in my basement keeps backing up. I have wasted money on plumbers to come out and unclog it and they do. I'm finally going to have a camera put down there to see what the problem is. I know for a fact that it is not tree roots b/c the snake only pulls out toilet paper. I know that this is going to be something that is going to be dug up. How much does this cost to fix? And if if is something that has to be done outside I know my drive way will have to be dug up also. If that does happen will the plumber have my driver way fixed or will I have to fix it myself? PLEASE HELP ME!!
pink06 is offline   Reply With Quote
Old 02-10-2009, 04:29 PM   #2
If you have tree roots in there the toilet paper and sewage would stop up against them. Therefore the TP would be the first thing a snake would pull out. The camera should help identify this issue if it is roots or otherwise.
Most plumbers I've met aren't pavers. Get an all around worst case quote before anyone digs. And know who charges what for their services. If the plumber hires the paver there will likely be an upcharge to you. Don't go in blind.
Chemist1961 is offline   Reply With Quote
Old 02-10-2009, 04:48 PM   #3
bradnailer's Avatar
It is quite possible that the rooter guy didn't go far enough with the snake. Sometimes they get the thing to start draining and quit. If possible, they should go all the way to the city connection. The camera will be a great help though. Hopefully, you won't have to replace the entire line.
bradnailer is offline   Reply With Quote
Old 02-10-2009, 06:11 PM   #4
The plumber said it's not tree roots because they didn't pull any of that out. They said it could be buildup or where the 4 inch and 6 inch meet that could have shifted and the stuff is getting caught on it. If I have to replace the pipe will that be expensive?
Old 02-11-2009, 06:24 AM   #5
Plumbers are not going to fix your driveway unless they are paid to do it, but why would you expect a plumber to fix a driveway, your concrete guy doesn't fix plumbing does he?
It depends on what you consider expensive, but you have not given enough information to even guess how much it would be.
What material is the drain line made of, how long is it, how deep is it, how much of the driveway needs to be cut?
bwalley is offline   Reply With Quote
Old 02-11-2009, 09:05 AM   #6
bradnailer's Avatar
Once you get the camera work done you'll be better suited to determine a solution. If it is a section where 4" to 6" has shifted, you may just need to repair that area only.
Old 02-11-2009, 11:24 AM   #7
If no roots are being pulled out, it is probably a break in the line. When this happens, the junction of the break sinks (from water seepage) and causes a "trap" situation that slows the flow of water and solids, including toilet paper. Not going to be a cheap repair. You will need to hire someone to fix the drive. A camera should be able to locate the problem area.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 10:52 PM
Condensor drain Captflx HVAC 6 08-17-2008 10:19 AM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
laundr y drain issue toddtrain Plumbing 1 02-23-2008 12:05 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
