Drain Installation - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-14-2008, 08:50 PM   #1
drain installation
hi evrybody,i was going to install a shower pan and plumb it but decided to call a pro.the instructions said not to nail shower pan flange but to put mortar underneath.when i got home from work i noticed the plumber put screws in it and cracked the flange,also the drain is a 2 inch pipe going through a rubber gasket(caulk sealer)into pee trap instructions said that pipe should be even with gasket but the pipe is a quarter inch higher and it allows water to sit around pipe.all in all it looks ok its just that he didnt follow the instructions and am a bit worried.he .thank you
GLASSMAN1 is offline   Reply With Quote
Old 02-14-2008, 11:45 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
If it isn't right per the manufacturer's instructions, have a heart-to-heart with the plumber and ask him to either re-do it or warranty his work in writing for at least a year for damages, etc.
Good Luck!
Mike Swearingen is offline   Reply With Quote
Old 02-15-2008, 07:05 AM   #3
Thanks Mike
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 09:11 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
Washer drain peloncito Appliances 7 08-04-2007 12:56 AM
How to outline the 1 1/2" PVC drain froddan Plumbing 6 07-24-2007 03:15 AM
Basement Drain + Carpet redwards Plumbing 1 07-21-2006 03:42 PM
