-   -   drain hydronic system to replace baseboard heater (http://www.diychatroom.com/f7/drain-hydronic-system-replace-baseboard-heater-83687/)
dap52521 10-12-2010 02:49 AM
I need to drain water from to baseboard heater i remodeled to bathrm and thats the only thing i have to do (replace the heater)not sure about the way to go about this i know alittle about the boiler two zones,gas
need to know best way to do this
AllanJ 10-12-2010 05:48 PM
You will probably have to turn off the furnace and open the valve on its boiler to let the water out that way.
You cannot drain just one zone unless it has manually operated shutoff valves on both the outgoing and return pipes as well as a drain valve within the closed off section.
NHMaster 10-12-2010 06:36 PM
If you are clueless here the best thing is going to be a call to your local heating technician before you get in over your head.
