Drain For Humidifier In Crawl Space - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-09-2010, 07:52 AM   #1
I ask the impossible!
Rewards Points: 704
Drain for humidifier in crawl space
Let me just ask what the best way to provide drainage for a humidifier on a furnace in a crawl space would be. What I have now is just plain not working. Horizontally, I have about 10 feet or a little more to the stack and vertically I have a few inches, don't know exactly but it's not much.
The current configuration for the humidifier is shown in this picture, there have been changes but not to the humidifier. For some reason, water is not flowing through the pipe that goes into the trap. I just don't like the setup, this particular pipe isn't secured on either end and just held up with a strap in the middle - that's it.
WillK is offline   Reply With Quote
Old 12-09-2010, 09:57 AM   #2
If gravity won't do the job, you will have to get a pump. I have a condensate pump that my dehumidifier dumps into. I know you have had several problems, cause I have seen that picture in several posts. So be sure your main sewer and drains are working properly, or a pump will not do any good. Maybe you don't need a pump if the sewer was draining properly? Man I am all over the place. Good Luck
broox is offline   Reply With Quote
Old 12-09-2010, 12:04 PM   #3
Rewards Points: 704
It's definitely the pipe, water is backing out of the top. Downstream problems in the sewer pipe would be apparent with other systems, when it has been blocked there has been gurgling in the bathtub, plus it would be backflowing out of the pipe above the p-trap.
Would I connect directly to the humidifier drain or do I need the humidifier to drain into some sort of reservoir or drip pan? Is something like a dehumidifier pump kit going to work, and anyone have experience good or bad with any particular pumps? A search for condensate pumps at Home Depot produced a Flotec pump which many reviews said failed between 1 year and 2 minutes.
Old 12-09-2010, 12:25 PM   #4
A condensate pump has its own little reservoir. So dump the drain from the humidifier in the pump. Then get some clear tubing and run it to the trap. I also might lengthen the standpipe or the vertical pipe out of the trap. From the picture it looks very short.
water in crawl space need advice puma80 Building & Construction 2 04-08-2010 10:07 PM
Whole in Crawl Space Wall? Water Problem? - Picture! donaldp General DIY Discussions 1 03-26-2010 08:52 PM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 12:09 PM
insulating crawl space near plate measure thrice Building & Construction 13 01-26-2009 03:11 PM
Drain configuration, which should I use? moneymgmt Plumbing 3 01-10-2009 09:10 AM
