Drain Hose Stuck On Washing Machine - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-10-2009, 11:04 AM   #1
Drain hose stuck on washing machine
I just bought a new house, and the old owner left her rubber drain hose (the black retake hose) for the washing machine. My washer has the drain hose coming into the body of the machine, so there isn't a place to clamp on her old hose. However, when I went to remove the old hose, it appears to be stuck. It rotates in the hole, but won't come off when I pull on it. My movers who were helping me said they'd never seen anything like that. How can I get the old hose off so I can put my own hose on? I've seen stuff online for getting the hot and cold intake hoses off, but that isn't my problem. HELP!!
savingedmund is offline   Reply With Quote
Old 05-10-2009, 11:07 AM   #2
Look down into the drain pipe. There may be a rubber collar inside it to prevent the hose from coming out during the discharge cycle of the washer.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 05-10-2009, 11:15 AM   #3
If there is, how would I remove it?
Old 05-10-2009, 11:19 AM   #4
Most likely just a slip-fit. It may be difficult (but possible) to remove since the soaps from the washer may have "sealed" it. If you can, pour some really hot water into the pipe to soften the seal. Then twist and pull.
Tags
drain , stuck , washing machine
Trap and washing machine safety drain pan wildbilly Plumbing 18 03-05-2013 08:08 PM
Washing Machine Drain handy man88 Plumbing 17 12-23-2012 08:16 AM
washing machine drain vent problems rebelbull Plumbing 7 03-29-2009 10:18 AM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 12:17 PM
Washing machine drain hose morrisp Plumbing 3 09-01-2006 08:24 PM
