Drain Height/Flood Level Of Washing Machine - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-13-2009, 01:43 PM   #1
Drain height/Flood Level of washing machine
Is there a required height the washing macine drain has to be at?
What is considered the flood level of a washing machine for vent height figuring; to the top of the door/flap/drum?
I'm in Minnesota if it matters.
wildbilly is offline   Reply With Quote
Old 03-13-2009, 04:56 PM   #2
Rewards Points: 1,538
I think that all that counts is the drain hose that came with the washing machine has to be able to reach, and where it fits into the drain pipe does not fit tightly. That is, the drain has to gravity feed from that point without a vacuum developing.
Specifically you may not splice an "extension drain hose" to the washing machine as the built in pump will get overloaded.
The flood level would be the rim of the tub for a top loading machine or near the bottom of the door (where water would flow out if the door were open) for a side loading machine.
Old 03-13-2009, 07:29 PM   #3
Rewards Points: 150
washer waste height
42"of the floor is what I mount the bottom washer boxes.That way you can get access to it behind washer.
rudolph58 is offline   Reply With Quote
Old 03-13-2009, 07:38 PM   #4
GC/Master Plumber/Mech
Rewards Points: 560
UPC Plumbing code 2006
Trap weir 18" from floor
Stand pipe min 18" to max 30" from trap weir
ICC Plumbing code 2006
Stand pipe min 18" to max 42"
No ref to min distance from floor
Point...
Check with your local codes office to see what the requirements are for your area
Old 03-13-2009, 08:09 PM   #5
Rewards Points: 150
only helping.this is what i mount them at and have never had a plbg.inspector in the state of IL.call me on it.as far as trap height and and distance from trap to waste outlet,that is per code.Purchased 2" glued p traps trap weir are established by the manuf.unless altered by the owner.
Washing Machine Drain handy man88 Plumbing 17 12-23-2012 07:16 AM
Patching into existing drain with washing machine Kimball72 Plumbing 5 02-01-2009 04:28 PM
Washing Machine Drain mqcarpenter Plumbing 3 11-20-2008 07:47 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 11:17 AM
Washing machine drain hose morrisp Plumbing 3 09-01-2006 07:24 PM
