Drain Gulping - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-08-2009, 06:07 PM   #1
Question
drain gulping
i just installed a new double sink with disposer, both down tubes are 1 1/4" and they go to a tee which goes down to a 1 1/2" trap and out the 1 1/2 " drain. a couple of seconds after the water has been turned off i'm getting a gulping noise. it does it about 3-4 times then stops. it does it every time i turn the water then off. what have i done wrong
ghopper57 is offline   Reply With Quote
Old 12-09-2009, 01:17 AM   #2
1. Your system is vented , right?
2. the run from the p trap down the drain is how long? hopefully more than 4 inches so your not causing a siphon to the p trap...
tell me where if it is vented, the vent comes into your line...
wiley0714 is offline   Reply With Quote
Old 12-09-2009, 08:08 AM   #3
thanks
thanks wiley luckily i left a 4" piece of pipe above the trap and someone else said to put a whats called a quick vent or i think he called it a studor vent ( used for venting in rehab condo's or townhouses ) thanks again for the reply
Old 12-09-2009, 09:39 AM   #4
It does sound like a venting problem. AAV's (Air Admittance Valves) are made by a few companies but Studor is the top of the line. I am wondering about the 1-1/4" piping though. Kitchen sinks are normally 1-1/2". Bathroom sinks are the only 1-1/4" drains I have seen or installed.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 12-09-2009, 12:56 PM   #5
thanks
the 1 1/4" pvc down pipe i was refering to was the size that came with the garbage disposal and it goes almost immediatly to the 1 1/2 trap. i put the studor vent on this morning and it works fine now. the reason i didn't vent it was before i installed the new counter tops and sink there wasn't a vent on the drain for twenty years and never had that problem. after changing the drains to fit the new sink i guess i did a better job than the guy twenty some years ago. thanks for the reply
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 03:25 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 02:46 PM
Condensor drain Captflx HVAC 6 08-17-2008 11:19 AM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 08:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
