Drain Grate Too Small For Drain Hole - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-17-2013, 07:26 AM   #1
Lord of Slums
Rewards Points: 1,974
Drain grate too small for drain hole
Was not sure if this belongs in plumbing or is a mason question. I have a 8 inch terracotta pipe set in cement that acts as a drain, it drains into just dirt. Sees very little water . When the old cover rusted out I have not been able to find anything close to what was in there. I believe the new drain covers are all metric. So now I have a big gap on the sides of the cover. I brought it too level with a piece of lexon. Should I put some backing rod in there and mortar the cover in?
mj12 is offline   Reply With Quote
Old 04-17-2013, 07:32 AM   #2
Rewards Points: 12,830
Got a picture, need to see what your seeing.
Old 04-17-2013, 10:05 AM   #3
Rewards Points: 1,418
You can mortar in a new cover so it cannot slide sideways far enough for any edge to fall into the hole.
Old 04-17-2013, 10:19 AM   #4
would this work?
http://stores.drainageproducts.us/-s...ate/Detail.bok
search for 10 inch grates
Old 04-17-2013, 10:28 AM   #5
Roofmaster
Rewards Points: 2,172
1. How can it be too level?
2. What is lexon?
Old 04-17-2013, 10:39 AM   #6
Concrete & Masonry
Rewards Points: 470
I would put some tight/stiff mortar around the outside edge and set the cover down into it, leveling it with the floor, or slightly below. Once the mortar sets, trace around the outside of the cover to give it a little clearance............
jomama45 is offline   Reply With Quote
Old 04-17-2013, 10:40 AM   #7
Lightfoot's Avatar
Rewards Points: 272
http://www.plumbingsupply.com/replac...in-covers.html
this place handles all sizes.
I'd cut a piece of nylon, or plastic the correct thickness (cut circular with a hole in the middle like a donut) to fit down in it to bring it up to level (less the thickness of the grate). Silicone it in place, then screw the grate down to it. It'll be there long after you're gone. My local hose, gasket, belt supplier has plastic (nylon) or similar material in a wide range of thicknesses and will cut whatever i need. It comes in big sheets like plywood (maybe not that big). Looks like you have about an inch or so to fill. Heck, they'd probably give you a scrap piece big enough for what you need. Just find somebody with a bandsaw and cut a circular piece out of it. Then a hole saw to cut the donut hole.
Flashlight: A cylindrical container used to store dead batteries
Lightfoot is offline   Reply With Quote
Clog at Toilet Drain Hole Lpitt56 Plumbing 2 12-30-2012 08:46 PM
Cutting a hole in floor drain cover for drain hose Rav Plumbing 8 12-21-2012 01:50 PM
Bath faucet pop-up drain rod won't fit sink hole location seavlad Plumbing 7 02-03-2011 07:23 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
Small Hole in copper roof vabrave Roofing/Siding 4 05-20-2007 05:24 PM
