-   -   Drain flies under house (http://www.diychatroom.com/f7/drain-flies-under-house-45844/)
fly slayer 06-02-2009 11:52 PM
I had a waste pipe (thank goodness not a sewage pipe, but only from my kitchen sink and dishwasher) break under my house. Floor boards were ripped up in one room and a swarm of drain flies emerged. I was told that by fixing the pipe, and leaving the floor boards open for a few days, the ground/sand would dry and make the environment no longer good breading ground for the flies. I have poured bleach down each of the openings- a bit daily. I have fans positioned down into the holes and a 65 pint dehumidifier producing two filled tanks of water daily. But I still have flies!!! Usually I see about 10 live ones on the walls and about 50-100 dead ones on the floors daily. It is better than a swarm, but ... ug!!
I have purchased InVade, but instructions seem to be limited to the pipes alone. Can I use it under the house??? If so, how??
Besides ripping up the rest of the house, what should I be doing??
Thanks in advance for any advice.
hayewe farm 06-03-2009 11:35 AM
You might want to read this http://www.doyourownpestcontrol.com/drainflies.htm
