Drain Field Modification - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-13-2011, 09:37 AM   #1
keeper of the skyhook
Drain Field modification
I've got a 3 year old 700' lpp drainfield... 7 rows, 100' each with a partial
mound of about 6". I want to shorten 10' off of each line on one end to
make room for a garage. House has two baths with 2 adults.
Do you guys think the system will be fine shortened the 70'? Is it worth it to
add the 70' back into the sytem?
thanks
bigcrush is offline   Reply With Quote
Old 01-13-2011, 09:58 AM   #2
Owner
LateralConcepts's Avatar
thanks
I would suggest contacting the entity that handles septic permits in your area (typically the local health department). Sizing of the tank and drain field is usually based on the number of rooms (not fixtures or people) in the house, soil conditions, perc tests, etc.
Good lookin' out though. Most people don't think about underground utilities when planning a project. Can't believe how many times I've seen patios, decks, buildings, retaining walls, etc., built over septic tanks, sewer lines, and drainfields.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 01-13-2011, 10:11 AM   #3
Owner
This is a good read.
http://www.nmenv.state.nm.us/fod/liq...AFactsheet.pdf
Lateral
(208) 818-8241
Old 01-13-2011, 10:14 AM   #4
you are removing one line from a system sized for your house, what do you think is correct here?
The older I get the better I was
Old 01-13-2011, 11:52 AM   #5
Rewards Points: 1,494
Seven rows seems like a lot to me but the soil probably is not that absorbent hence the need for 7 rows.
The system was designed and installed at or close to the minimum requirements for your house (bedrooms, etc.) and land (perk test, etc.). So you cannot simply decommission part of the system to make room for your garage.
You could get a septic company come in and design just an addition next to your field in a different direction to compensate for the part you want to decommission.
Old 01-13-2011, 01:24 PM   #6
thank you all for your thoughts.
It seems excessive to me as well... every other house in my neighborhood have gravity fed systems with much smaller drain fields then mine.
I'm thinking about adding a new 50' line off the center feed line along side the other rows (installing the same way as the existing drain field ie: trench, gravel, pipe, gravel, fabric then topsoil). This will result in only a 20' loss, and provide the room I need for the garage.
I still have the prints from when it was installed to go from.
Septic Tank not flowing into leach lines or drain field michaelschier Plumbing 19 09-01-2010 07:58 AM
Septic Drain Field ekulrenlig Landscaping & Lawn Care 16 04-27-2010 09:59 PM
Replace Drain Field? namderd Plumbing 1 04-20-2008 07:59 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
Severed septic drain field line tripower Plumbing 2 08-14-2007 01:05 PM
